FactoryTalk View Studio Machine Edition Password Protection
InControl
Oct 2004
Arkansas
29
I have almost completed a project using FactoryTalk and the client wants to password protect a numeric input on all screens. Does anyone have an idea of how this can be accomplished. I don't want to affect other items on the screen and i dont want to have to password protect each whole screen. In this case the value to be protected is a setpoint and they want the operator to have to enter a password to change the value. Any help will be appreciated.
What I normally do is create a numeric display, then an invisible numeric input enable with a visibility animation. Use the function CurrentUserHasCode() in your animation.
When a user is logged in, the numeric display will be 'visible' and able to be touched, and when the user is not logged in, the numeric input will be 'invisible' and not able to be used.
The numeric display is visible the whole time so you can still view the value.
One thing I forgot to mention - make sure you flash the latest firmware for PV+, or install all the patches if using a PC. There is a bug where using CurrentUserHasCode() can drastically slow down the runtime. I had several apps slow to the point of crashing before I discovered the fix.
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
133
Hi all, I'm having an issue with connecting View Studio emulation to a real PLC. I am running View Studio 8.01 on a Hyper-V virtual machine...
260
Hello. I have a Project I'm doing in Factorytalk View Studio. One of my displays I created has a bunch of red x's on all of the objects I created...
697
So, I'm new to the PLC world (fresh graduate) and at my job I've been pretty much only helping out the other programmers with simpler tasks while...
625
Good morning, I have a project coming up that will require my HMI runtime to toggle from English to Spanish via selector switch. What is the...
459
