Simatic PC Adaper USB with Virtual PC....
nightline
Feb 2010
Prinsenbeek
425
Gents,
I've a Laptop with W7 64 running, and MS Virtual PC for WindowsXP.
On this WindowsXP I've installed Siemens Step 7 V5.4, and like to attach my Simatic PC Adapter USB.
When connecting this Adapter and attach in Virtual PC, the driver is installed, but gives the error code 10 ( driver cannot start ).
Can anyone give me some tips to solve this problem?
Jack
Hi!
As for my expirience, try to avoid Virtual machines when using Siiemens sw. It will never work fine. I tried to istall Step7 V10.5, it failed.
Now I have Multiple OS (C: - Win7 32, D: Vista 32) instead of VM and all works fine.
Hello,
I also have W7 64, multple VM running Siemens software and they all work perfectly. I have Premium Studio 2009 on one virtual machine and PCS7 v7.1 SP2 on another and my old lap top converted to virtual running all kind of PLC software.
Only I am using VMware instead of MS Virtual PC. I used PC Adapter and CP5711 without any problems...
Hello,
We are not allowed to run VM ware on our systems by our IT guys, so I've do it with VM.
My Siemens Simatic Manager is version V5.4.0.0 without any service pack. So maybe this is part of the problem.
Where can I download these service packs?
Regards,
Jack
I have a copy of Microsoft's Virtual PC. The last time I checked it didn't support USB.
I run Step 7 on my VM Ware. It works well with both Profibus and Ethernet. Our product also has a USB port and that works with the VM Ware too.
Edit, I am actually running VMWare's Fusion on my Mac Pro at work.
Hi I have Step7 running under XP Mode of win7 pro.
Remember to install the USB driver under win 7 and inside the VM... and use the USB menu to attach it before use.
My gripe is that the Step7 VM hard drive is getting very bloated.
Cheers
Cheers
Can you explane a little more what you mean with installing the USB driver under W7 and inside VM?
Which version of driver and USB adapter are you using?
Jack
Hi I have a standard genuine siemens usb adaptor with the supplied cd.
basically install the drivers so win7 recognises it. Then attach it to the virtual machine (see menu bar - usb - select from list - attach)
Then install driver under the virtual pc (xp pro in my case)
Then select usb adaptor, auto settings, within the virtual pc control panel
We are facing intermittent issue with emergency stop and line stop. Line stop triggering with alarm of line stop push button activated at one...
216
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
108
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
188
Hi, I received this SIMATIC S7-300 training kit for maintenance. When I power it up, the PLC doesn't go to RUN mode and the STOP mode led is...
323
I'm trying to build my Classic Step 7 programming skills this weekend. I get stuck on little things that are not covered in YouTube tutorials. I'm...
334
