grant.dotulong
Hi all,
I'm having trouble programming the analog output on my Allen Bradley Micro850 with OF4 extension. I enabled the channels, minimum-maximum output range 4-20mA, with the data format in engineering units. I'm trying to control an inverter wired to a motor. I used the MOV instruction block to assign my analog output with values from my analog inputs, but it seems that the analog output does not produce any signals (tried with my multimeter) even though there are values in CCW's live mode. Does anyone have the solution for this?
Thanks,
-Grant
Thanks,
-Grant
