Siemens PCS7 V8.1 SP1
shazad5444
Feb 2014
Houston
126
Dear friends, I recently installed Siemens PCS7 V8.1 SP1 on my Windows 7 Ultimate. I'm a new player in the field of PCS7. I have problem while I'm creating "New Project Wizard" after completing all steps I click finish. Then progress bar appears, there are about 4 to 5 bars running on progress bar a message appears " Server busy. With some text to switch another????" I click retry and then appears below message
"PCS7 Wizard (2772:106)Internal error creating plant hierarchy".
I spent lot of time to dig out the answer of my question on all forums and Siemens website but didn't have any luck. I hope someone will help me to resolve this problem. Thanks in advance.
Kindly, did you solve this issue? How? Thanks
Project language. PCS7 requires US English to be defined and can only accept certain languages. This is somewhere in the settings for the project, although it's been a while since I used it.
Ok.
Actually, my problem is a bit different from Shah's. But i was checking his, to find any similarities that might help.
My problem is the following.
After retrieving a PCS7 project on a new laptop, the Hierarchy folders are not shown anymore, in the Plant View.
All necessary softwares look already installed, and no compilation errors are shown, only some warnings.
Thank you
Sorry for delayed reply as was busy on some projects, I think u r missing some necessary files which needs to be install. Select all necessary files and install, I hope it will solve your problem.
Hi Guys, Please, is 6ES7658-4XX58-0YT8 #K1-30 Trial Version/License OR Runtime License OR Engineering station AS/OS License? SIMATIC PCS 7 V9.0...
1,316
Hello All, I am not very familiar with the Siemens architecture however, I was looking into a possible application. The current Siemens PLC is...
4,227
We've used Acronis previously on site to take images of PC's and I thought it would be beneficial to make use of the continuous backup function in...
1,292
Dear all i am using PCS7 V6.0 SP2.we are planning to add totalizer and one timer in CFC and display the value in Wincc.How to do the program in...
1,841
I am currently working on a sizable project involving Siemens PCS7 on an H-system using WinCC for graphics. The project is still in development...
5,482
