Is there a shortcut through RSLinx to the Processor
TheWaterboy
May 2006
-27.9679796,153.419016
1,939
A minor annoyance I often have is browsing through the "Who Active" list and then drilling down through the tree past the backplane etc to connect to a processor in Logix. It's several clicks more than I think it should be. I mean, when using Logix we never connect to anything else in the "Who Active" tree except the processor so why isn't that easier? Like a filtered view
Is there a shortcut method where I could have a list of PLC names and just select one of them them directly?
Yea its trivial but I'm curious. I saw shortcuts in RSLinx but they don't appear to Logix.
Well yes I know there are exceptions - I'm just wondering if there is another option for my workflow . I could open the ACD first but I typically don't.
I feel your pain and, no, I have never found one. The best I've been able to do is to learn to 1) abort any "automatic" searching, 2) always highlight the Driver, then 3) wait for red X's to show up (there are almost always multiple devices that are not connected) and, finally, 4) find the appropriate communications device and drill down to the processor.
I've often wondered why they make it so cumbersome and, yet, give you that almost-worthless "automatic" search when it can't drill down all by itself.
In the RS-Linx Configure Drivers for the Ethernet adapter, you can type text after the IP address, and this will show up in RS-Who. This can be helpful where the IP address is for a backplane Ethernet module, and therefore will not have a processor name automatically associated with it.
Oh ? I know about :EIP. didnt know text was also available.
How long have you been doing things the hard way?
Next time you've located the PLC in Who Active, on the lower right there is a button that says, "Set Project Path". Press that, save your .ACD, and the next time you want to go online, merely select "Go Online". Logix/Studio will remember the RSLinx path.
Now, if you are sharing the .ACD with a lot of other people, this might not work. The reason is that you might use the AB_ETH driver, and have the IP configured as "Station 10", while Joe might have it as "Station 0", and Fred uses AB_ETHIP. But even then, your copy of Logix/Studio has a "Path" selector -- View >> Toolbars... >> Path Bar (if it's not visible). This lists all your recently used paths, with the PLC name associated with it, just like what you want RSLinx to do!
Select the path, select Go Online, and Presto!, you're there. No browsing required.
The ACD (and the RSS and RSP files) are indeed shared between 2 users and 4 machines so to do this means RSLinx needs to be identical to use the project path. That's not insurmountable, just looking for this option to eliminate that potential hiccup.
Apparently it doesn't exist.
If recent paths could hold 100 entries that might work.
"...this means RSLinx needs to be identical to use the project path. ...
It is possible (and relatively easy) to synchronize everyone's RSLinx. Make one copy the "Gold Standard", export it using the RSLinx Backup and Restore Tool, and import everywhere else. The management of the "Golden Linx" should be managed just like you do ACD files -- no "private" copies.
As for needing 100 entries -- if you've got that many PLCs in your plant, then you really should be having the project path set within with the ACD file, and making sure that everyone accesses the PLC the same way.
Otherwise, you're going to be browsing no matter what you do, either through RSLinx or a list of paths. For that many, Linx is probably easier.
Good luck!
we have same HMI 2PC / SET LOCAL STATION version 9.0 patch 2021.dec and win10 pro v18.xx 1pc install logix5000 v19 v20 It was going well...
218
To copy a tag name in S5k we can, *right click an instruction *open the edit properties dialog box *and then copy the tag name text If we...
1,568
Is there a tag properties keyboard shortcut in RSLogix 5000 for an existing selected tag? I know Ctrl+W will allow you to create a new tag. But...
2,474
Hello all, I am having trouble when I try to open my .mer from the PV. It keeps telling me "Uncofigured shortcut detected". The problem is, when I...
1,468
Good Morning , This is what I get when I started a project 5 months ago , and then get back to it , with a new 1769-L33ER, into my existing ME...
1,945
