Editing Shortcut for PanelView Plus
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Hello all, I am having trouble when I try to open my .mer from the PV. It keeps telling me "Uncofigured shortcut detected". The problem is, when I tell it to load my file it gives me this alarm so I am unable to use the Application settings tab at the HMI. This is an existing program that I created the .med from the .mer so the laptop hard drive is different than the one that created it. I am not sure if that is the issue or not. I didn't change the device shortcut name in the FTView Studio project, hoping to avoid this. I did change the offline tag file, since it had the original project designers name and location in it. I did perform the Copy from Design to Runtime and I think it uploaded all my new tags appropriately. I was online with the processor when I uploaded the tags and didn't get any errors when I verified. I think I am skipping a step but I don't remember, since it has been several years since I have last performed this.
This is for the communications links? Did you successfully browse the processor from the shortcut? I know I've done it before where I hadn't clicked on the new shortcut, and it just overwrote an old shortcut to a new location. I would try making a whole new shortcut, just to prove it's working right.
Hello everyone. Is the PLC CJ1M CPU13 capable of online editing? Or only downloads that will stop the PLC? Thank you.
344
Hi, its been awhile, hope y'all are well. I do not have RSView Studio or whatever the HMI specific programs are for working with .mer files I have...
278
Hi all, Does anyone know if WAGO 750-8100 with e!****pit supports online editing? Thank you.
720
Often I type in the commands in the text bar as I find it much faster than other ways to add or modify instructions. However the text bar is...
2,042
Hello all, I am currently running a program from an S7-1200 and I am using TIA Portal v17. I have created a user-defined web page to eliminate...
1,559
