editing a Panelview Plus program
Skidood
Oct 2016
Ontario
215
Hi, its been awhile, hope y'all are well.
I do not have RSView Studio or whatever the HMI specific programs are for working with .mer files
I have a program for a PV Plus 600 which was developed 14 years ago, I believe the FW rev level is 5.1 or 6.1
Is there any way at all that I get into the .mer file and change a PLC address (I think its just a binary bit) ..the HMi is looking at this bit and when it switches to ON, the HMI will change the background color of a pushbutton on the screen.
Is there any free software out there that I can use to work with .mer files?
You might be able to access the communications profile/options from the Panelview configuration screen, but if it's something that's written in the programming itself, you'll need RS View Studio Machine Edition. I don't know of anything else that can read .mer files, and that old of a revision is probably not editable directly, .mer is the Machine Edition Runtime file, compiled from the programming and then transferred to the Panelview. It is not normally editable.
Yeah, I figured that. I just spoke with a PLC specialist who told me the same thing. I only work with PLC stuff maybe once a year so it makes no sense financially for me to obtain the required software.
Hello all, I am having trouble when I try to open my .mer from the PV. It keeps telling me "Uncofigured shortcut detected". The problem is, when I...
1,440
Hello everyone. Is the PLC CJ1M CPU13 capable of online editing? Or only downloads that will stop the PLC? Thank you.
344
Hi all, Does anyone know if WAGO 750-8100 with e!****pit supports online editing? Thank you.
720
Often I type in the commands in the text bar as I find it much faster than other ways to add or modify instructions. However the text bar is...
2,043
Hello all, I am currently running a program from an S7-1200 and I am using TIA Portal v17. I have created a user-defined web page to eliminate...
1,559
