Slow Omron NB when using USB as log storage
Apr 2012
mexico
We are working with an omron NB Hmi and a Cp1L PLC.
These devices are monitoring and storing a temperature Log in a USB memory connected to the NB.
the problem comes when we insert the memory and then the HMI operation becomes very slow
Any ideas why this could be happening?
we tested 2 USB one was an 2.0 8GB memory and the other was a 3.1 USB which worked a little better.
but the specifications of the NB shows the USB port is an 2.0 port
Thank you very much for your help
http://www.edata.omron.com.au/eData/HMIs/NB/V122-E1-05.pdf
"When operations become slow or when a periodical process cannot be
executed as specified.
Check the available memory space on the LW9136 system memory, and secure the adequatememory. (LW9136 shows a reference value for available memory space.)
The periodically executed processes such as alarm detection, data logging, timer, or macro mayhave a longer execution interval than specified or not be executed, depending on the loads caused by screen display or communication, or the overlapping processes. Check the actual operation to adjust the load of the process."
This is in section 5 Maintenance and Abnormality Handling of the above manual.
Regards,
Anyone is suffering very high latency on keyboard and or basically everything using Sysmac Studio on a virtual machine? I am using i7-4th gen 32GB...
4,835
Does anyone else have an issue downloading from their Automatic updater? I typically get around 1MB/sec this is running around 70kb/sec. Is...
3,349
Hi, I have CX Programmer version 8.01 and have become (didn’t happen with an earlier version) frustrated when I go "online" (typically serial...
6,266
Anyone have issues with RSLinx being very slow to open. It sometimes will say "Checking Activation" at the bottom for what seems like an...
152
Hi All, we've recently upgraded from FTView SE v10 to v12. Since the upgrade we've been having a problem where the HMI is slow to update tags in...
88
