A few years ago I had a problem with a motor running a hydraulic pump. We used a hand held data collector to get the motor current throughout the cycle. Then my hydraulic guy took the data dumped it into Excel and calculated the RMS current of the motor. The idea was the motor could go into overload though the cycle as long as the RMS current of the motor was less than the rating on the motor. So he broke the cycle down into chunks where the current was constant. Took the amps and the time and calculated the RMS current of the motor though the cycle. We found that we could remove spikes in the current lowering the RMS current and keeping the overload from tripping. All things were well.
Fast-forward 2 years and I have a similar problem on a different machine. I have installed a current sensor on the motor and took it into my plc. I already have a way to collect the data and store it so no problem. I took this data and did the same type of calculation my old hydraulic guy did. I would like to take this to the next level. I would like to do these calculations on each part doing an RMS check on the entire cycle and do some peak readings at different times. The peak readings are no problems but I don't know the best way to do the RMS. The overall cycle changes depending on the part they run so it has to be somewhat flexible. I was thinking about breaking the cycle down into the segments I want to get the peak in. Then doing an RMS of each segment then an overall.
Has anyone done this type of thing before? I don't see any reason I can't do this but I don't want to put time into something that could be done easier.
Comments and suggestions welcome
