PLC Allen Bradley
plc\'sman
Guest
P
Hi all,
I have to use an PLC Allen Bradley.
My customer told me that the software i need is the "control logics"
and "panel builder 32" for control panel.
Do you know if the software is shareware (it's possible to dowload) or other solution.
Thank's to all
There is no free Allen Bradley software. You will have to spend a good amount of money.
Contrologix is a PLC. The software is RSLogix 5500. For the PLC5 it is RSLogix5 and for the SLC500 it is RSLogix500.
You can contact a local AB distributor for pricing.
They do give away thr pico controller software. not much there, just fun to play with.
Here are some suggestions on what to do:
If the project in question is BIG, then you should easily cover the expenses for software and some training within the budget.
You could also let a third-party do the programming, but this would not be less expensive, only it is probably the fastest way to meet a short deadline.
If the project is rather small and dont allow for extra expenses, then consider this aproach:
Ask the customer to do the programming of both PLC and HMI himself; he probably allready is proficient in ControlLogix and PanelView as he is requesting them.
You will be a consultant on how the system or machine shall function. Use your existing PLC listings as a template for the customer.
The end-result: You dont have extra expenses. The customer gets what he wants.
Of course, this assumes that it is acceptable for you to hand over the programming to the customer. And that it is acceptable to the customer to take over the responsibility of the systems functionality.
yep...swinging his arms about, light flashing on his round barrel body....usually Dr Smith was the cause of all problems.
Hello, I am new here. I am trying to find good places to sell some surplus items that I have that isnt through ebay. Does anyone have any sources...
427
Hi good day Everyone, I have a cimplicity v10 project with 7 to 8k tags communicating with AB PLC through OPC and Rslinx classic. I have this...
219
I am using Allen Bradley PLC 1756-L81E and EIP module 1756-EN2TR for Ethernet/IP communication. My communication works fine but in Get-Attribute...
203
I have a network with 4 PLCs PLC1 is controllogix and PLCs 2-4 are compactlogix and they all need to communicate. The current way I have this...
262
Hi Everyone, I am currently trying to communicate ControlLogix PLCs via EtherNet/IP with Delta V DCS. There is a VIM2 card configured for...
280
