Kinetix 6500 Config
kjacoby
Jul 2011
Right Here
91
Good morning,
I am currently setting up a new 6 axis Kinetix 6500 using RS5000 20.01. In my program I already set up the axis', and the electrician wired them up differently than I planned. When I go into the settings, and change the axis, from 6 to 4, the motion type changes to feedback only, and will not allow me to change back to position. Is this something AB did on purpose, to prevent the axis from being changed accidentally, and causing unexpected movement? If not, is there any way to change this back to a position move, without deleting the axis' that are already setup, and starting over?
I was trying it with an offline file. I went ahead and swapped cables around to get it going. I would still like to know if it is possible to swap axis numbers without deleting the configuration and starting over.
Swap - One Way - Export the Project to L5K
- Find the Axis and change the Axis numbers over
Dear team, We are constantly facing M07 incremental loss on one of our kinetix 6500 safe torque. We have changed Servo motor (MPL-B4530K-MJ72AA)...
139
Loving AB right now... We have an Allen-Bradley 2094-EN02D-M01 Kinetix 6500 servo drive that once had safe-speed monitoring which was eliminated...
156
Hello, I encountered a problem with the kinetix 6500 drive, error code s22, loss of 3 phase voltage. After disassembling and replacing the thermal...
190
Hi everybody, I am having an intermittent issue with a Kinetix 6500 drive. The fault i get is a SAFE FLT 05, described as GuardFeedback1Fault in...
905
A line in our plant has always had an issue where everytime the jar filler stops/restarts, it wastes 5-8 bottles because of underfills. FWIW, the...
1,833
