Factory Talk Studio Global Object - PIDE PV communication failed?
plctek
May 2022
toronto
23
Hi everyone, I am trying to add a control loop to my HMI interface however I keep getting the following issue, any idea why this would happen?
You're using PlantPAX faceplates... so you need to use an instruction called PPID for them to match up. The regular PIDE will not work with them. Is this what you're doing?
Which PlantPAX version are you using?
Weird, because
Hey, im using the faceplate from the 5.10 graphics library. The object that I am using is labelled as a PIDE icon. When I specify the global parameter values, it also tells me to select the PIDE tag not the PPID tag.
And when I load the program, the SP, PV and the OP all popup, just the associated faceplate that pops up with that icon doesnt work.
Why would that be the case?
There's quite a bit I'm missing here... first of all and most importantly, are you using a P controller?
If not, then you chose the wrong library and need to go back to 4.10. Library 5 is made so that it only works with P controllers.
The other thing is that I can't find the file where you got the PIDE symbol from. I can't find it on my installation, but there is a PPID file where a similar symbol is located. Was the PIDE symbol copied from a PlantPAX v5 library?
ok i just changed my library from 5 to 4.10...
I am still currently having the same issue after downgrading from 5 back to 4.10. Is there a feature on my actual PID loops that is causing this that i need to enable or what?
just fixed it
for all of those of you wondering, the shortcut that I created in the communication setup had a space in it, "Link Tag", strangely enough, it shouldve been something like "Link_Tag"
I am trying to enable an external alarm via computer speakers for Factory Talk Network Distributed Edition. I am using Alarm and Events setup. I...
172
I have some global objects, numeric display with associated data that pulls up a pop up screen. for the life of me i cannot figure out how it...
236
Hello everybody. I was wondering if there is a way in FTVIEW Studio to close ) view after x min without interaction . My issue is the following...
364
Is there a way to choose the base font in ME. Text in the Arial Unicode MS which is the default font on my FTVS doesnt show up properly on a...
678
Hello all, looking for ideas on getting some basic training done, I need to practice on maintenance timers and bypass switches (with a Factory...
1,316
