Can you post your .rss and the .apa and tell us what you are looking for and maybe we can help you solve this.
You are really swell to offer, but I don't think I want to do that.
I hope you will read this post even though it is kinda long.
It aggravates me that I don't even know the correct terminology.
My question is this: In a general way, how would you go about finding something in Factory talk?
In the ladder logic you have elements... inputs, outputs, what I would call( probably incorrectly ) internal relays, etc.
These elements have addresses that identify the slot and terminal, or the variable I:2/3 O:4/6 N7:30....
In RsLogix 500 I can find these elements by doing a search: Find All I:2/3 .
And I will get a list of all I:/2/3, and where they are in ladder logic
I know I'm not telling you folks anything... I'm just trying to explain where I'm coming from...
In more recent years, you can give these elements names... Tags.
Instead of I:2/3 You can call it "ConveyorStartButton".
Perhaps I am wrong, but in RsLogix5000 I don't think you can even find them by their address anymore, but must use their tag. If I'm wrong I'd sure appreciate someone straightening me out, because I'd like to be able to search by address.
But that is beside the point.
My perspective is always from the troubleshooting end or modifying end of something that someone else did... never from the creation end. I need to find why outputs don't work as intended, or perhaps make them work a little differently.
When something doesn't work as expected, you have to start at the output and trace back what controls and modifies it.
That will often lead you to integers which are changed by mov instructions or something else.
Hang on. I'm almost to the point.
When It leads you back to the program that is in the Panelview1000, and you have to use Factory Talk,(about which I know little or nothing) how do you
find these elements... the integers or what ever... ESPECIALLY when you think they may not be assigned correctly. Remember, this started because something did not work as it was supposed to.
In a general way, how would you go about finding something using Factory talk? If I suspect N7:30, how do I find everywhere it may be affected in the Panelview program?
How many times does it appear in the Panelview program?
