Maintenance required. Error in lower level component
Right under Diagnostic Status, you see the Diagnostic Buffer. Check that.
The diagnostic buffer is is a very important step with any Siemens PLC, for sure.
Another great tool is to, right click on the PLC and check "receive alarms", then go down to the bottom under the diagnostics tab (properties/info/diagnostics) and click on Alarms.
The diagnostic buffer shows you an event history, but sometimes you need to dig a bit to figure out what is wrong right now. The Alarms tab shows you all the active alarms from the PLC.
I think my problem occurred because the CPU and the factory's server are not synchronized.
I received an alarm regarding this.
Ok I've been given the task to create inventory control, pm, and all the other fun stuff that goes with running a maintenance team. Just so you...
24
8,209
Hi all. My maintenance department is clamoring for the ability to look at the PLC programs (and we finally have some who can read it.) I have a...
544
Hi all, Anyone got Preventive Maintenance Checklist for Rockwell PLCs? I found this article, but it does not clearly talk about PLCs, though it...
456
This is a little OT, but I know there are some experts here on the forum with the relevant experience. I have a project that expects a very long...
1,082
1,118
