Communication via rs232 v24 having S5 3964R protocol with Selogica controller
EngrRizi
Sep 2011
Luxembourg
Dear All,
I want to communicate with Arburg Selogica controller v3.09 of an old Arburg injection molding machine. The protocol by which this machine can communicate is Siemens S5 3964R through serial R232 V24 C 25 pin port. End goal is to get process data real timely to then send it to kepwareEx server for further analysis. Even though the kepware server has builtin driver for Siemens s5 PLC (S5 3964R protocol), but apparently it can not communicate with Sologica controllers. I have contacted Arburg and according to them I may need to write my own software to read the data from Selogica controller. I don't know where to read data block from i.e. address of the tags etc. I will be thankful if someone can help or give some pointers to resolve this issue. Or a small piece of script to read the data from controller.
Regards
Rizwan
Thanks for the reply.
I'm using CM1241 (RS422/485) module. Manual suggesting to use the Recieve_P2P block to get the data.
I'm attaching the Serologica manual, there it describes how the data will come.
Can you please go through it, and suggest me that the Recieve_P2P block itself enough to get the data?
Thanks in Advance!!
Hi, I work at the company. I need to communicate with the PLC SLC 5/05. I already tried to connect but when i press "Auto configure" on RSlinx it...
2,104
Hi All. Wonder if some1 can help me. Im using a FX3G mitsubishi PLC and want to communicate via the RS422 coms port instead of adding a 232-BD...
4,096
Hello you all PLC masters.... I am working in one Oil Industry and I have a SLC 5\05 and it has some problems such as.... 1. FLT LED blinking---...
20
20,088
Hi all, I have a studio 5000 project that incorporates a Rexroth Indradrive Cs servo amplifier, a Kistler Joiner, with a maXYmos measuring/control...
37
Good day, everyone, We're trying to establish an S7 connection on ethernet between an S7-400 CPU and a new S7-1200 CPU (which is defined as slave...
2,730
