FactoryTalk SE Popup on every client causing a problem
OntheFly
Nov 2019
Henderson, Nevada
Hello, this is my first time posting and I am looking for assistance for a specific issue I am having. I am doing work within FactoryTalk SE that involves using multiple thin clients and multiple screens to see data from. This issue is specifically referring to a popup that occurs every so often that--when clicked--will trigger an action in the code.
The popup displays on every screen, however when the action button is pressed, only that respective popup goes away on that respective screen. All the other popups on all the other screens still exist. The problem occurs because, as those popups exist, the action button could still be pressed by another operator, triggering the bit in the code again and reversing what was done.
The VBA code looks like this:
Private Sub "Variable_Name"_Change()
If "Variable_Name".Value = 1 Then
Application.ExecuteCommand ("Display "Variable_Name"_popup")
End If
End Sub
On the popup itself the button properties look like this:
under the 'Action' tab
;Abort
;Toggle "TAG_FOLDER"\"TAG_NAME"
I'm very inexperienced with automation and there is so much to learn, so if this post is hard to understand or if I haven't conveyed my problem/current config well enough then I apologize. Any input on this would be greatly appreciated.
The goal is to have the action item be able to be pressed on only one popup and have all other popups disappear along with it. I implied that, but I understand that intention should be clear, concise, and not left open for interpretation.
I have done this using the PC or PanelViews IP address to condition what terminal the screen will pop-up on. With SE and VBA it's much easier, with ME I had to create a separate tag in the PLC for each PanelView to monitor in that case alarms (based on IP address).
Good morning, I'm new to PLC and HMIs, and I was given the following problem: I need to be able to filter alarms and events that are only related...
389
Hi, When I open a property configuration popup, it is zoomed in so I cannot see all the configuration options. I don't know if this a Windows...
2,743
Here we are in v12 of FactoryTalk View and from what I can tell, we still don't have a quick and easy way to close a popup after opening a new...
4,155
Hi all, i'm new working on FactoryTalk SE. I need some help with this little thing. I have a popup wich should be closed if i click outside the...
1,595
I created a window that pops up over the existing screen being displayed (similar to a faceplate) but buttons around the perimeter of the window...
2,115
