Logix5000 plc to EtherCAT slaves
Manglemender
Jul 2007
Lancashire
1,295
Hello,
I have a new project on the go that will have a Logix5000 PLC and needs to communicate with 12 slaves that don't speak Ethernet/IP.
This was previously done through RS232 to each slave but the new models now support EtherCAT. Can anyone share experience of getting comms to multiple EtherCAT slaves from a Logix5000 plc?
Many thanks,
Nick
Thanks for that. I did find that with google too and have made an enquiry. It looks like it behaves as a slave so do you not still need an EtherCAT master? Would I need one for each EtherCAT slave?
Nick
I wondered the same. "The gateway acts as a Slave/Adapter on both networks." has me wondering; an inquiry to Anybus may clear that up.
ps: if it can act as a Ethernet/IP slave and a Ethercat scanner, you win.
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
428
Hello everyone, I have an RSLogix5000 project which is running live in the factory but I need to make some changes to the logic. I want to test...
1,121
What is the best way to set a bit over an ethernet/IP network on an Allen-Bradley ControlLogix Series PLC from a Windows PC. We have a program...
2,105
Hi everyone, How can I know what type of tag do I have to use? Like if i have a coil that is connected only to contacts and can be used by all...
2,939
I am an Electric Engineer working as a maintenance engineer and manage some technician on the production hall now but in the past, I mostly focus...
3,553
