Allen Bradley PLC-3 analog values - some change, some frozen
shanefaulkner
Oct 2009
Buffalo, NY
56
This hasn't become my problem yet, but it may soon...
Ancient PLC-3 (yeah, I know) has been humming along for decades. It now has some analog values that are moving and some have frozen in place. For example a watts transducer is reading 1056 kw when it should read 0.
That's all I know at this point. I've never been online with a PLC-3. I'm wondering if maybe the block transfers for certain modules have stopped executing for some reason.
Posting here on the off chance someone has seen this before.
I have spent many hours programming on a PLC3 as well as PLC2's
i would recommend that you upgrade it soon a failure could shut down the plant
as for the analog module if memory serves they have a failure / open input mode that you set in the module on a failure drive the input reading either full scale or 0 they
it could be up scale or down scale depending on your application
with a power monitor I would expect it be set for up scale
i would check out the power monitor I have have to replace a few of them over the years in the US i would just replace them with a current input.
A power monitor checks both the line voltage and load current an delivers a single for that. but in the US the line voltage is constant within a narrow range and it doesn't change much so a simple load sensor will do the the job at a much better cost
Hello, I am new here. I am trying to find good places to sell some surplus items that I have that isnt through ebay. Does anyone have any sources...
413
Hi good day Everyone, I have a cimplicity v10 project with 7 to 8k tags communicating with AB PLC through OPC and Rslinx classic. I have this...
219
I am using Allen Bradley PLC 1756-L81E and EIP module 1756-EN2TR for Ethernet/IP communication. My communication works fine but in Get-Attribute...
203
I have a network with 4 PLCs PLC1 is controllogix and PLCs 2-4 are compactlogix and they all need to communicate. The current way I have this...
262
Hi Everyone, I am currently trying to communicate ControlLogix PLCs via EtherNet/IP with Delta V DCS. There is a VIM2 card configured for...
280
