Unable to select minor fault in controller properties
Chris K
Feb 2016
North East
Hi All,
I was looking thought controller properties and I turned on battery fault in minor faults in controller properties(1756-L62 ver.16.20)and as soon as I did this other faults that has been checked (program and watchdog) went unchecked and now I cant turn on any of them. What could be the reason for it? Thanks!
If memory serves me correctly....
This field is intended to be a view of the current minor faults. Checking or unchecking them does not change the fault status. You cannot cause a battery fault by checking the box and you cannot clear a fault by removing a check. But if you do remove a check, the check marks won't reappear until that fault re-occurs.
I might be corrected if my memory has faltered me.
OG
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
233
I've posted this on the ptc forum as well, but no luck with an answer (waiting for my service contract number) I keep getting the following error...
123
I have just installed Studio 5000 V30.11 on my Windows 11 Pro machine. First I had an "Invalid Pointer" error that required me to update Factory...
118
Hi, One of my customers has an old fabric tensile testing machine. The IC # AD7501KN of its controller has malfunctioned. This IC is related to...
80
Hi all, I'm having difficulties trying to connect FactoryTalk View SE Local Station (V13.00) to MS SQL Server Express. I state that they are...
133
