Kinetix 6500 MSO ERR#22 Stop the axis before you execute this instruction
taylor1982
Aug 2011
Bavaria
78
with my Kinetix 6500 axis system I have the very random problem that the MSO instruction fails with error code 22 "Stop the axis before you execute this instruction."
When I monitor the MyAxis.ActualVelocity tag I see indeed sometimes very very low values. But only for a short time then they return to 0.
Can anybody give me some hints to solve this? Tuning? Allow MSO only when velocity = 0?
We have a lot of machines running with the same configuration and this is the first one I get this MSO error.
Hope that somebody can give some input, thanks a lot!
I had the same problem with a K5500 after a running motor got stopped by an emergency stop or guard door opened. I added a MSF instruction before the MSO instruction.
i have the same issue, i am doing the msf then the mso, but the mso does not work.
should i do some delay between the msf and mso?
or add some axis bits logic before calling the mso instruction?
Dear team, We are constantly facing M07 incremental loss on one of our kinetix 6500 safe torque. We have changed Servo motor (MPL-B4530K-MJ72AA)...
111
Loving AB right now... We have an Allen-Bradley 2094-EN02D-M01 Kinetix 6500 servo drive that once had safe-speed monitoring which was eliminated...
132
Hello, I encountered a problem with the kinetix 6500 drive, error code s22, loss of 3 phase voltage. After disassembling and replacing the thermal...
167
Hi everybody, I am having an intermittent issue with a Kinetix 6500 drive. The fault i get is a SAFE FLT 05, described as GuardFeedback1Fault in...
882
A line in our plant has always had an issue where everytime the jar filler stops/restarts, it wastes 5-8 bottles because of underfills. FWIW, the...
1,826
