cardosocea
Hello,
I inherited a project where the previous guy designed a comms ring to go around the site to connect all the existing PLCs. He specified an awful lot of redundancy to be added because his original plan was to leave all PLCs in the same room and install IO all around the site on this fibre ring.
The fibre ring would eventually have VLAN's to separate Safety, SCADA, and PLCs. The site settled on Rockwell and it would be a much bigger cost now to move on to another vendor so we're sticking with them, meaning that the network switches were also specified as Stratix (57 or 5400).
When reading forums, etc... yesterday I came to an interesting post where the IO running on top of a ring like this would suffer if the ring broke since the reconfiguration time is higher than what the IO modules would like to see.
Personally, I dislike the approach very much as I like to see physical segregation and Device Level Rings wherever possible, but with all the hardware out on site, I'm tempted to take a chance on some systems, but not if something like this has the potential to shut a plant down.
Has anyone here done something like this? And what is your opinion on the best way to do it? Mind that we're moving from SLCs and a bunch of Micro and Compact Logix to a few Control Logix in the near future.
