USB to parallel converter
Chance85
Apr 2005
Mid South
55
Hello everyone
Has anyone had any issues using a usb to parallel port converter? I need to use some software that requires a dongle, however the p.c. I have to use doesn't have a parallel port.
No experience, but I'm guessing that it will be much like a USB to serial converter. That is your mileage may vary.
Ive used one for an old Panduit label printer I have. My laptop, of course) doesnt have a parallel port. It works, but i have to tell the program to print twice to get it to work.
I did extensive research few months ago for a different project:
While most of USB to serial converters emulate COM port, all USB to Parallel converters will not emulate parallel LPT port and will create Virtual PRINTER Port
Dongle applications typically need direct access to parallel port and will not work with USB
The other option would be to use a card bus/parallel converter but I cannot be sure it would work either but they are cheap.
I had the same issue with a Sentinel dongle. I was able to get it working with a PCI bus parallel port card. Mapping the dongle to the port was a little tricky, but it works now. Computer was a new Lenovo desktop without a standard parallel port.
Background: We have some age-old HMI software that runs on Windows 2000 only. Until now, we have solved the problem of supporting this old HMI...
21
13,034
I am looking for an adaptor to drive a USB printer from the parallel port of my Citect SCADA PC. I understand that such adaptors exist and that...
10,390
Anyone know of a cheap foundation fieldbus communicator? Something like the USB 8486 H1, but one that does not cost $3k? Thanks, Trevor EDIT: I...
111
please using the usb can i assign any ip address that i want ?
151
Dear all, I have fx3u series plc with built in rs422 port and usb-sc09-fx cable. I have a a hyperterminal like application to send and receive...
223
