bits'bytes
Hello Jesper,
can not tell for sure, as I was not able to download any version before 2.5 (from 2007)
But I found this news on B&R Homepage:
http://www.br-automation.com/cps/rde/xchg/br-automation_com/hs.xsl/news_2776_ENG_HTML.htm or see attached picture.
On Jan. 9 of 2004 B&R announces the USB dongle, so I am afraid a PVI version of 2002 will not work.
Another hint for you: when you run the PVI setup you will find an option screen where you can choose the components to install. There is the parallel dongle. if there is no USB dongle to select your PVI will not support it.
In my opinion you will need to upgrade PVI ....
This can be an easy task - you dont need to touch your HMI, just install the newer PVI version. If it works - good for you. If you encounter some problems or unexpected results I am afraid you have to think it over again...
You can also try the lowest version you can download (2.5.x) instead of the newer one. I think the chance everything works is better with an older version.
good luck
br
bb
good luck
br
bb
