Beckhoff help (long shot)
the_msp
May 2008
Northern Ireland
1,271
Hello, so I guess I'll start by saying I didn't design this system, or even am responsible for it's maintenance... just trying to help out and hopefully you can help me out there...
The system is a full production line which is cellular and one cell is not working due to ERR lights on all IO modules.
The software (Twincat NC 1 V2.10) reports a "cfgData" error for the profibus slave adaptor (ILxxxx-B3xx)
The profibus tab shows the following under "cfg Data":
B2 B2 B2 B2 B2 B2 B2 B2 1F 16 20
For another cell that is working fine it shows:
B2 12 20
The slave adapter has been changed (same result) and we are currently going round all input modules (1x2300) with a spare input module and also using that to test the output (hope this doesn't generate it's own error) as we don't have any spare festo 1x4404 units.
I tried downloading an earlier program and had same issues in this cell.
Thanks Garry, it's definitely:
Error code 7
Error code 7 indicates a variety of errors when checking the CfgData. The error argument describes the error.
Error argumentDescription1The length of the CfgData received is not correct2The syntax of the CfgData received is not correct3The length of the DP input data that has been calculated from the CfgData is too large4The length of the DP output data that has been calculated from the CfgData is too large
Could a physical issue (e.g. fibre) cause this or is it more likely software related?
I have a Beckhoff CX7000 IPC with some digital I/O built-in and I additionally need two analog inputs 0-10V. Can I install both Ethernet terminals...
211
Any help for a Beckhoff PLC that does not start up correctly the first time? The system will lock up, stop responding at times, requiring me to...
1,778
Dose anyone have experience with Beckhoff FC3121 profibus master PCIe card connected to Siemens CP342-5 as a profibus slave? The data retrieved...
17
4,811
Hi, I have received a copy of a PLC program for a customers Carton erector that uses a beckhoff PLC and HMI. I just downloaded the trial version...
2,272
Ok working on TwinCat for first real time. I cannot seem to find a way to do a compare in the ladder. The way our driver works (from our...
28
13,849
