Long Shot Win CC Flex 2008 SP1
Secret
Aug 2005
Beds
55
I know this is a long shot but here goes.....
I am trying to import a Protool project using an old laptop with WinCC Flexible 2008 SP1. in doing so it comes up with an error
Could not find file c:\Documents and settings\All Users\Application Data\SIEMENS AG\SIMATIC WinCC flexible 2008\Caches\1.3.1.3_102.3\Read\Template_en.tmp
I have found it on a laptop with SP3 but the folder was 1.4* not 1.3* and it didn't work.
could anyone with this old version on a VM or old laptop send me a copy of their temp file?
I can't get to work to check if we still have the install discs until next week, if we do I'll try re installing it?
Or is there another way of importing an old protocol project? I'm currently running WinCC flexible 2008 SP3 on this laptop.
I'll give it a go, got nothing to loose at this stage.
PM'd you my email address.
Cheers for that (y)
Done.
Check your e-mail.
The file name may be an issue as it is a "tmp" file and your outlook may reject it.
I can rename to a "zip" and re-try.
Let me know.
Hi Tufty mate,
I've got
1.3.0.0_183.1
1.3.1.0_167.2
1.3.2.0_158.1
1.4.0.0_116.16
..in my directory
Give me a shout if you need any of those zipping up and firing on. :)
Done.
Check your e-mail.
Let me know.
Hi Bill you are right it's blocked it, could you see if zipping it makes a difference?
Cheers
Hi Tufty mate,
I've got
1.3.0.0_183.1
1.3.1.0_167.2
1.3.2.0_158.1
1.4.0.0_116.16
..in my directory
How do Jonny Bareback,
I'll let you know 1.3.1.0 might be worth a go if 1.3.2.0 throws a wobberler....
(y)
Hi Tufty mate,
I've got
1.3.0.0_183.1
1.3.1.0_167.2
1.3.2.0_158.1
1.4.0.0_116.16
..in my directory
OK buddy your up. The first number is the build, the second number is the service pack so can you chuck me 1.3.1.0 I'll PM my email address.
Cheers
Hello all. This is a very lonnnnnnng shot but worth a try. I have an OMS Group Impact100 metering machine. At this customer it blows foam into 3d...
186
Hello, so I guess I'll start by saying I didn't design this system, or even am responsible for it's maintenance... just trying to help out and...
2,041
Background: We have some age-old HMI software that runs on Windows 2000 only. Until now, we have solved the problem of supporting this old HMI...
21
13,034
Does anyone know of a free flow simulator for product [granular] in a silo and through the hopper? Thanks, Bob
1,697
I have Allen Bradley plcs, I have had Circuit breakers and other automation equipment in the past. There's no solid buyers local. How much do you...
204
