Engineer_UA
Greetings guys,
Does Cisco 4000 series require a power supply? Looking at the cut sheets, it can tolerate input voltage level 10-60 V. I don't understand the benefit of adding a power supply. As long as voltage on the bus the Ethernet switch is connected to is robust, it seems the switch can be connected directly to the said bus.
Any thoughts?
Thank you,
EE
Any thoughts?
Thank you,
EE
