VFD control
lennox1974
May 2011
england
i am looking to to install VFD speed control on six fan motors using a allen bradley PLC any pointers on how this project would be helpfull
At minimum, a VFD requires two control signals. One signal to tell it when to start, another to tell it how fast to go. Both of those signals can come from the PLC.
The run command is typically a contact closure. The speed command could be an analog signal. It could also be one or more contact closures which tell the VFD to select one of several preset speeds.
But, rereading your original post, I'm not sure I answered the question you asked. That's because I'm not sure what the question was. Do you want help on how to implement PLC control of a VFD or do you want reasons why PLC control of a VFD would be an improvement over the way the fan speed is currently controlled?
Hello, I’m new to this forum and if I’m posting incorrectly let me know. I’ve been having an issue I can’t seem to figure out. I’m sure it’s...
119
Hi there, We have a system at a water treatment plant where large raw water tanks feed into the plant that's all on the same level. At high tank...
18
3,763
Hello, So I was asked to turn up the speed on a VFD to allow a carriage to move a little bit faster and avoid getting stuck. Im not sure the exact...
736
Hello everyone, I have yet another thread about PID's coming your way. Any PLC5 users in the house? I'm currently writing a program and have...
2,128
I am controlling a very tight window in a 8 foot sump. My low level to keep from cavitating the pump is 44” and my high level is 55”. The problem...
2,070
