chandrapaul
OP
Yes, I can see from your picture you are connected to X127
I suggested you connect either via profibus or the Ethernet connection on the plc if there is one.
As there are no connections on the X127 ports the implication is that they are not being used.
I have attached the control unit model image. Will it work with the ethernet cable or need profibus?
