10A motor Starter Over Ethernet IP or EtherCat
mad4x4
Mar 2009
ST CYrus
363
Looking for Ideas for a distributed control system and need to start a 10A Motor (DOL) or Revsing (DOL), would rather have a EthernetIP conncetion to the motor starter rather than having to put in a distributed IO box for DO's and Din's.
In the Past we have done the same with TESYS U over profibus or Modbus. is there a similar product that will allow start stop over either EtherNet IP or EtherCat? Doesn;t need to Schenider.
I could put a VDF on the motor and control that but VDF control on this is not required and being 3phase @ 10A load makes the VFD to large and a bit of overkill and costly
Have 5 Motors to address in this fashion all distributed.
I use these all the time "Modbus TCP". You can order with Relay outputs but I just use there DO and wire an external relay for "SINK".
They work very well.
https://www.aliexpress.com/item/Mod...Watchdog-Supports-10MHz-High/32838142273.html
Turck also makes a very compact Ethernet-based IO modules. Here is one flavor:
https://www.automationworld.com/art...ethernet-digital-i-o-modules-built-web-server
Doing it this way or with small-scale remote IO will likely be cheaper than Ethernet-enabled motor starters.
You would probably be better off in the long term to just install a small remote rack.
Reason being, you will most always need to add things later. Sensors, coils, etc.
As mentioned, cheaper too.
Unless you need to take advantage of the features like a E300 has. Need to reset overloads and monitor power readings over Ethernet? If not, then remote IO is best option.
Hi All, I have set up a Moxa NPort serial server for an application. Unfortunately the environment requires NAT forwarding between 2 systems...
822
Hello This is my first post on this forum so I will take this opportunity to say hello to everyone. I'm new to the PLC programming and...
2,053
If anyone has experience with this electrical controlled pilot valve for Danfoss Series 90 pump, could you please explain to me how I'd control...
2,057
Hej Guys. Is anyone that has knowledge about setting up communication via ethernet from Keepware OPC server to MOXA NPORT? the keepserver keep...
2,015
I have a problem with the table feed while machining. Speed ​​feedback is taken from armature voltage measure. Settings: Nom motor volts...
2,543
