Danfoss MVC110A control
Jasondelane
Mar 2015
Florence sc
221
If anyone has experience with this electrical controlled pilot valve for Danfoss Series 90 pump, could you please explain to me how I'd control it. The data sheet says it's current controlled but it doesn't get into specifics. Do I use a dual or single channel current output module? How do I reverse the flow to reverse the hydraulic motor? PLC is a Compactlogix L32E with Point IO for remote IO.
Thank you
You will need a valve driver for this that accepts a 4-20mA signal. I don't believe that you can drive this directly from a PLC card.
I'd contact the supplier and see what they recommend.
Update:
I found the valve driver in the old cabinet for the previous machine. I can't find any information on it with the labels that are attached. Just going to wire it up like I found it and go with it.
Hey guys. As the title suggests, I need to configure a Danfoss Aquadrive FC202 inverter, so that its logic inhibits the local command when the...
48
Hi all, We are currently experiencing an DC over voltage fault on one of our inverters. During commissioning a snag was raised whereby excess...
202
hey guys i've been trying to find an updated SW files of my danfoss fc360 for MCT 10 software but i couldnt be able to find it anywhere on...
255
Hello all. I am hoping someone here has installed a Danfoss VLT Midi FC 280 and connected an encoder to it. I am just trying to make sure I select...
462
Good morning! I'm trying to communicate a Micro 850 (2080-LC50-AWB) with a Danfoss FC202 by VLT 121 MCA Ehternet ip card. I can read the value...
453
