Hi All,
I have set up a Moxa NPort serial server for an application. Unfortunately the environment requires NAT forwarding between 2 systems
RedLion DA50 NAT Config:
- TCP + UDP
- Bidirectional
- Masquerade: enabled
- Gateway symmetry: ignore
- Whitelist: None
Telnet, Ping and Remote COM port are working fine across the NAT.
MOXA web interface is not working and returns "Bad Request".
Web interface can be accessed from the Moxa local network.
Any ideas? Other devices behind the NAT are displaying web interface without issue.
- TCP + UDP
- Bidirectional
- Whitelist: None
