Communicating MOXA NPort 5110 to CPU315-2DP through CP343-1
Jun 2013
Monterrey
I am trying to get data from a Serial Barcode scanner from a Siemens S7-300 CPU 315-2DP . I am using CP343-1 ethernet Interface Card and a MOXA NPort 5110 (Serial to Ethernet Converter) . Does anyone have an example on how to make this communication?
I would really appreciate some help
Serial cannot be converted directly into Ethernet and vice versa.
Moxa NPort can only work together with PC with special driver installed (for Windows, Linux, BSD and some other OSes), but not with PLCs.
(I'm not familiar with Siemens, and may be wrong). The only solution i think is to get serial module for Siemens and connect your scanner to it. Also, the PLC software should support the scanner communication protocol.
Dear All Please help me about Below picture problem.PLC not communicating proper.
185
I need to recommend a PC to replace a customer's old Windows 7 computer. The only thing I need to think through is the serial com port to...
21
705
Hello Friends, We have a powerflex that stopped working sometime last week. It doesn't communicate over the network, or use CCW directly from my...
464
Hi All I'm trying to connect two zebra printers to th PLC through Ethernet. I can ping the Printer through my laptop connected to the private...
367
Have a customer that has a running 1756-l83es, communicating to redundant ABCIP IO servers for Wonderware 2020. This configuration has been...
890
