Online over Moxa N Port Half Duplex Slave
dutch4892
Jun 2015
Wisconsin
I'm trying to engineer a cheap solution to get online with remote slave devices using the below configuration. I see there was a forum post about using these devices but that wasn't real helpful with the area I'm stuck on. In order to make this work I know I need to use a DF1 Polling master driver in Linx but has anyone had any success virtualizing a comm port over Ethernet to get online remotely this way before? If so what software did you use? Seems like most of the software for this out there is something you have pay for :/ This is between a 5/03 and a 1000
Hi PLC people, think about this scenario: The PLC is somehow connected to the same network with the facilities` network. Then someone connects to...
89
I'm trying to verify a project with a PLC. The Transfer Setup menu item is grayed out and every time I click Verify with PLC, I get an error...
76
Hi. I’m trying to upload program from existing PLC S7-1200. Create new project in TIA v15.1 then upload. After upload successfully, go online but...
244
Does anyone know of a way to detect if someone is online with the controller in ControlLogix (from logic) I'm thinking that maybe there is a CIP...
408
Got a VIPA 315-2AG23 that i try to go online with but can't seem to make it work through a network. I can go online if i'm plugged directly in the...
283
