plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old July 17th, 2017, 05:14 AM   #1
Bagus
Indonesia
Bagus is offline
Output did not come out, coil did not turn green
Hi All, I just starting out CX-Programmer. I am currently using CPM1A.
At first day all is good and I can try different program using basic program such coils, contacts, Timer and Counter. But then in the second day my PLC dont give any output. I try to use simple program, like this :
----| |-----------O----
but the LED on the PLC's output display did not turn ON, and I look at the ladder diagram the contact and line turn green but the coil don't. I try to turn it off and on then transfer new program to PLC but it still the same
I'm still new with this and I can't find the solutions for this problem.
Hope you guys can help me with this problem. Thank you so much for your attention.
Old July 17th, 2017, 05:29 AM   #2
soenderhegn
Denmark
soenderhegn is offline
Have you download the code?
Have you used the cool bit more Than 1 time
Old July 17th, 2017, 05:39 AM   #3
JamieRDennis
United Kingdom
JamieRDennis is offline
Double Addressing
Try and check that you only have 1 coil for the address 200.00 and or no Word or DWord or Real is written to 200
Old July 17th, 2017, 06:06 AM   #4
Bagus
Indonesia
Bagus is offline
Quote:
I have tried to use the coil with output addres but it still teh same either. Did I miss something in my process?
Old July 17th, 2017, 06:09 AM   #5
Bagus
Indonesia
Bagus is offline
I have tried to download from PLC using Auto Online and I think there's nothing wrong with the simple program that I upload before.
---] [-----------O---
0.00 10.00
my program that I tried to upload then I download again is shown as a figure above.
Old July 17th, 2017, 06:10 AM   #6
Vadagor
Spain
Vadagor is offline
Is it possible you forced those variables?
Or, as other people said, are you using the addresses somewhere else?
Cheers,
Nick
Old July 17th, 2017, 06:13 AM   #7
Bagus
Indonesia
Bagus is offline
Cheers,
Nick
Hey, Nick. Geeting from Indonesia.
I think I dont force anything because I just use a simple code with few contact and coil (basic program). Is it possible that this problem occure because there is a bug in my software so the program did not work preporly?
Old July 17th, 2017, 06:17 AM   #8
JamieRDennis
United Kingdom
Hi it looks like you've used the address twice for a coil so the PLC works in the First in First out order.
In rung 1 you may be turning on the Coil but then the Coil is reused in rung 5 where it is turned off. So at the end it shows coil off
Old July 17th, 2017, 06:21 AM   #9
Vadagor
Spain
Vadagor is offline
I have no experience with Omron, so I just suggested the common mistakes you can have. Even when it is possible, I would discard the software bug at this stage.
One silly question (remember, I have no experience with these plcīs): addresses "10.00" and "10.01" are actually "Physical Outputs" with LEDīs associated?
Old July 17th, 2017, 06:24 AM   #10
JamieRDennis
United Kingdom
if you have a Coil that required multiple uses. a word out of the way say 5000.00 to - 5000.01 for the control side then at the bottom have something like this.
5000.00 200.0
------| |-----------------------O-
| 5000.01 |
|__| |______|
Old July 17th, 2017, 06:26 AM   #11
gtsuport
United States
gtsuport is offline
From the screen shots, the processor is in Stop/Program mode.
The processor must be in either Run or Monitor mode for the logic to work, coils to turn on.
Hope this will help.
Old July 17th, 2017, 06:28 AM   #12
Bagus
Indonesia
Bagus is offline
5000.00 200.0
| 5000.01 |
|__| |______|
I use the coil twice because i want an interlock so the output will stay ON. I have tried just using Input and Output but the output still wont come out. I try program like this below.
Old July 17th, 2017, 06:30 AM   #13
Bagus
Indonesia
Bagus is offline
10.00 and 10.01 actually assosiate with LED and there a little LED display output in the PLC for every active Inpyt and Output so if the output work we can see it at the PLC.
Old July 17th, 2017, 06:37 AM   #14
Bagus
Indonesia
Bagus is offline
First of all, you have a good eyes, Sir. I think that's my problem. I'll cek again tommorow because the PLC that I used recently belong to my office so I can't take it home. But I think this is the main problem so my output did not came out. Thank you so much, I knew I miss something but can't figure it out. Thank you, Sir.
Old July 17th, 2017, 04:55 PM   #15
BobB
Australia
BobB is offline
BobB's Avatar
Yes - it is in program mode - first thing I noticed. Put it in monitor mode so you can do online program changes - not possible in run mode.
__________________
The Old Pfhaart
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Output coil instructions, help! Johnoates91 LIVE PLC Questions And Answers 7 February 20th, 2014 12:33 PM
double coil syndrome sandhya LIVE PLC Questions And Answers 31 April 17th, 2013 06:36 AM
How a Ladder is Scanned Sarit LIVE PLC Questions And Answers 19 April 28th, 2005 10:42 AM
Output Coil Instruction in LAD Unregistered LIVE PLC Questions And Answers 18 March 27th, 2005 11:32 PM
Update/evaluation of internal relays/contacts...PLEASE HELP s_viswesh LIVE PLC Questions And Answers 18 October 14th, 2002 01:58 PM
