Bosch Proportional Amplifier help.... datasheet or any info??
jkelleyus
Oct 2012
Westfield, Indiana
All,
I have an older machine which uses Bosch Rexroth proportional control for pump tilt and relief. The pump would not tilt.
We tested command signal from the PLC (+-10 vdc) and found it to be OK. Main pump tests OK by manually manipulating the servo proportional pressure.
This nailed our problem down to either the valve or the amplifier. Replaced the valve with no difference. Replaced the card with an Ebay buy (card is discontinued) and it works but must need calibrated.
I need help finding a data sheet and/or instructions for the Bosch PN 0811 405 011 (pic attached). Pic denotes a total of four front facing adjustment pots...but I have no idea what they do or how to properly calibrate.
Any help would be greatly appreciated, folks! Thanks!!!
John
Hi guys, Can anybody point me in the right direction to locate a EDS file for a Bosch Weld Timer PSS6000? I have trawled the Bosch Rexroth site...
503
Hi all, I am experienced with Rockwell by have recently encountered a Bosch PLC. It’s an IndraControls XM21 V14. I installed the software and...
794
Hi everyone, I have received request to troubleshoot an old Bosch device. Bu t I'm not familiar with it. Anybody know how and which software I can...
891
Specifically Sm10/20-TC. I have a customer that has a setup running a crosslapper, and this module runs the outfeed apron. They were having a lot...
1,352
Good Day I trust you are well, I am struggling to find someone that is familiar with the software "bosch Rexroth Indralogic Engeneering" I am...
1,557
