can an Allen Bradley SLC 5/05 Revision B be swapped for a Revision C or D?
Physically, for certain yes. And it will be compatible with every I/O module ever made for the platform.
In theory a Series B controller might have been firmware updated to a later firmware revision than a Series C or D, but it's unlikely. The Series C or D will have a 10/100MB higher performance Ethernet daughtercard, but it will support all the functions and features of the older controller.
I am looking for the full version of the Software, thank you for your help
399
HELP! I've been searching & searching for the software to run my SLC150 PLC for DOS 6.22 and for some reason, every link I have found for it -...
1,174
Hello! We have a drum rotation machine controlled by a AB SLC 500. The drum rotation inputs comes from a encoder into a 1746-HSCE. We are using 2...
1,153
2,271
Im in need of some help. I recently had the power supply go bad on my input output cards. I replaced the power supply and now the CPU is flasing...
1,411
