Allen bradley slc 500 High speed counter encoder fault
dotrixe
May 2020
Falun
Hello!
We have a drum rotation machine controlled by a AB SLC 500.
The drum rotation inputs comes from a encoder into a 1746-HSCE.
We are using 2 channels AA and BB. The encoder is supplied with 24vdc.
Every 5 - 6 month the machine have trouble to rotate. We have to replace the 1746-HSCE card. The card itself have some cracks and burnt resistors.
Have anyone else this problem or any idea what causes this?
I am looking for the full version of the Software, thank you for your help
374
HELP! I've been searching & searching for the software to run my SLC150 PLC for DOS 6.22 and for some reason, every link I have found for it -...
1,152
Hi all, Client has a hard faulted SLC 5/05 Revision B CPU, and I'm wondering if a Rev C or D can be directly swapped. Thanks!
1,125
Hello! We have a drum rotation machine controlled by a AB SLC 500. The drum rotation inputs comes from a encoder into a 1746-HSCE. We are using 2...
2,249
Im in need of some help. I recently had the power supply go bad on my input output cards. I replaced the power supply and now the CPU is flasing...
1,392
