Crimson 3.0 Emulator through Modbus to Click via Keyspan USA-19HS
I guess I should just ask if anyone can help with driver settings to use the the Click Programming port (fixed Modbus, 38400, 8, Odd, 1) and how I should configure the Red Lion to communicate. This is my first time with Modbus RTU to a HMI.
I just did a little project using a G304K and Click. Attached are the settings I used. I set up the G304K as the master, so aside from one rung of start/stop logic in the PLC, my entire program runs in the G304K.
You should have ZERO trouble getting this to work, Paul... (y)
-Eric
Totally off topic, but worth mentioning...
I didn't have the Click software installed on my home PC, and my version of the Crimson software was that 'non-genuine' build. Therefore, in order to look at my programs, I had to download and install both pieces of software.
Downloading AND installing BOTH took me LESS THAN FIVE MINUTES!!!... Why is it that the 'other brand' software takes F-O-R-E-V-E-R to install?!?!?!
Thank you, Red Lion and A-D (or Koyo, or Host, or whoever wrote the Click software). Well done!... :geek:
-Eric
Thanks for the tips. I believe I may have a conflict related to various drivers on my home PC preventing the driver from working through the G3 Emulator.
I may tinker with it more later this week.
How do you have the emulator configured? Modbus should work just fine through the emulator.
Hello Kind Folks, On my Red Lion Crimson, the "Send to Emulator" box is greyed out, and thus I'm unable to run the emulator. Has anyone run...
3,477
Hi Experts! I am trying to get a Redlion Crimson 3.0 HMI to talk to a Rockwell Emulator. I imagine I'll have to use OPC DA. Has anyone done this...
1,187
Using a Raw serial driver in Crimson 3.0 I'm trying to test some code. I've written some code to transmit so ascii characters with PortPrint() and...
1,098
Hi there, I'm very new to all this and I would like to ask for a bit of advice. If possible, can someone please point me in the right direction...
1,188
Hi, Has anybody found a way to make RedLion Crimson 3.0 Emulator "talk" to Rockwell Studio 5000 Emulate (within the same PC, running Windows 7...
1,964
