Using a Raw serial driver in Crimson 3.0 I'm trying to test some code. I've written some code to transmit so ascii characters with PortPrint() and I'm trying to read with PortInput()
If I map to a physical com port when using the emulator. It crashes.
If i comment out my PortInput() line the emulator works fine and I can capture the data on the comm port.
I replaced the PortInput function with a while loop and PortRead and I can read from the port.
Does PortInput work in emulation?
