Crimson 3 PortInput RS232 G09
VJTX
Oct 2007
TEXAS
126
I cannot get input from pc terminal to the Red Lion G09. I can send to the terminal.
Does anyone have a sample program to read a few chars from Realterm to a tag on the hmi?
I would advise using Microsoft products for HMI, instead of the 3rd party products. You will have so much power & flexibility. The terminal support is natively built-in & very inexpensive. Let me know if you need any help. [email protected]
Using a Raw serial driver in Crimson 3.0 I'm trying to test some code. I've written some code to transmit so ascii characters with PortPrint() and...
1,098
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
152
Hi, I'm having an issue in crimson 3.0 when I create a programme using a case statement referencing a fault word that each bit needs to change the...
308
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
134
Has anyone found a way to convert/replace/update the firmware on old Parker TS80xx series HMIs (i.e. TS8010, TS8006, etc) to accept Crimson...
121
