slick_william
Hello brothers and sisters of PLCTalk.net,
I am working with a PLC5/40 program which uses RSLogix 5, and am wondering if there is a way to export the Cross-Reference results to some kind of text or .csv file?
The idea is that we are taking an old PLC offline and I want to check each physical I/O before okaying the removal. I exported the tags and wanted to also export the Cross-Reference so that I could make sure to capture each instance of where any physical input or output may be used.
I looked in RSLogix 5 for something like this, also did a bit of online research and didn't find anything about whether or not this is possible.
Thank you and happy coding to you all,
Slick
Slick
