Hmi delta
May 2020
istanbul
Hi
I am programming a Delta HMI model DOP-103BQ with Delta Plc DVP-sx211t
I am having problem with displaying/reading data from PLC(counter, timer, data values, etc.)
Additionally, when I try to input data in HMI, it writes the data into the PLC (say for example Timer set value) but the HMI does not read/display those data.
It seems that the HMI is only able to write, but does not read the data from the PLC.
Can you help me?
Thank you
How are the two components connected?
The last time I ran into something like this (not on Delta hardware) the two devices were connected over a serial port cable, and the cable was not wired correctly for the application.
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
38
Hi, We have a customer that has an old DOP-A80THTD1 that is needed to be upgraded Can we upload from these units? Is there a special...
95
Hello, I know little English, I want to use 4 plc cqm1 as slave (modbus), and hmi delta as master. Unfortunately, I cannot establish rs485...
585
I'm trying to establish communication between an HMI DELTA (DOP-B07E515) and a PLC IDEC (FC6A-D16R1CEE) via the RS-232C/485 module (FC6A-SIF-52)...
567
Hello, I'm facing a problem in communication between my delta TP70P-32TP1R HMI and DVP20EX2 PLC. I tried multiple ways in order to set the...
1,333
