Transferring tag values from one RSLogix5000 file to another.
radfahrer
Nov 2006
Boston
156
Does anyone know a way to export/transfer tag values from one Logix5000 file to another? The situation I have is I've got a program running on an OEM skid which I do not have the original source file for, it has an array of tags (~600 values) used to store recipe values. We found a bug in the code, so we called the supplier, and they have sent us an updated version of the code, but it was updated from their original source code, so their values in the recipe registers do not match ours. Is there any way for me to transfer the tag values from my running PLC into their source file prior to downloading it to the PLC?
I tried the Export to .CSV function, but that appears to just export the tag's configuration info (name, type, description) not its value at the time of export.
Thanks,
Greg Krueger
There is a way to transfer tags to keep the values. You have to have both programs open and do a drag and drop. With the source file, high light the tags that you want to transfer to the new file. Drag the tags while holding the mouse button and drop them in the last slot of the Edit Tags tab (where you can create new tags.) The major problem with this method is that the tagnames in the new file cannot exist, otherwise it will change the tag name.
There's a utility called "tag upload download tool" that is on the RSLogix 5000 CD in the tools folder. Install that and it should do what you want.
Hi, I am wondering about transferring RS Logix 500 & 5000, as well as Rslinx to a new laptop. The one I currently use in the field is ancient. I...
700
I have a micrologix 1100 that I am trying to read three data points from it on my safety plc using studio 5000. Any tips or guidance is appreciated.
873
Dear Sir, We have Windows 10 Dell laptop with RSlogix Studio 5000 installed in it. Now we have purchased a ex-proof laptop with Windows 10 and...
2,681
Hi all, How can you transfer a bool value from one db to another I have used l & t to move words from one DB to another but it won’t let me move a...
1,440
I developed an InTouch application in 10.1 in a virtual machine. I developed all the Windows to be 1024x768 for the touch panel it will be used...
4,772
