Wago IO-Link and HART Modules Sensor Configuration
theColonel26
Feb 2014
West Michigan
785
Does anyone have any experience with Wago's IO-Link Master or Hart Master modules?
I would like you know if I can configure IFM IO-Link Sensors, in some kind of GUI form verse having to do it in code. If I use them with a generic Codesys runtime for the PFC200. They would however be on remote Fieldbus Coupler.
The same for the HART Module CAN I use it as a FDT DTM passthru to configure ABB sensors?
I think Wago and the like have support for FDT DTM. There are FTD containers which are free of charge, such as PAXCTWARE. What I am not sure about is whether the Wago DTM (Data-type manager) is free of charge. If there is a DTM for the IO-Link or HART master, it shuldb be very easy to configure, as the DTM supports easy-to-use graphic user interface.
Hi everybody for my project i need to collect some data from WAGO-I/O-PRO 32 by using DDE links. I did exactly what the help documentation...
2,960
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
83
I have a project to setup base programs across multiple PLC platforms that can be used for Modbus communications to various sensors that have...
121
Hello, I m having a problem with wago 750-862 plc. The plc won't start automatically in run mode after a power reboot. I've also tried the...
355
Hello everyone, I am trying to setup a Wago 750-8100 PLC to send a text message out via ethernet port, if I get a Digital input that is true. I...
344
