hvac system wifi network
dwoodlock
Nov 2012
Cincy/nKY
568
Just wanted to check and see if anyone has dealt with any of this. I'm looking at retrofitting some of our older 20ton units to a newer thermostat with remote access.
These units are all Trane of various generations, about 20 in total. Our newest hall has the Trane "Tracer SC" network control system, and our experiences with it have made it obvious that its not what we want going forward.
Just figured someone here may have done some of this before.
Just to share my experience trying to playing BMS engineer one time.
Even though I'm more familiar with PLC, it's more work than it's worth trying use PLC for HVAC. VAV (variable air volume) controller are lot cheaper and got all the necessary sensor build-in already. Lonwork and BACnet are the two protocol these system uses and you can always use a protocol gateway to connect to a PLC system for supervisory control.
At the time I was looking, Alerton seems to have the type of products I was looking for but I have no first hand experience with them.
I appreciate your advice.
I am definitely not trying to roll my own control system with a PLC. I Just thought perhaps someone here had been involved in a project where they implemented some sort of wifi thermostat network or something.
The stuff I'm looking at is just roof units pushing air down into the plant, luckily no ductwork or flow control involved.
Hey all, I do not have the original source code of a Modicon M172 PLC (HVAC PLC). I want to modify some of the code but read you cant upload...
339
Hi. I have taken over a Building Management System that hasn’t performed well since installed. It’s a ControlLogix main with wireless messaging to...
21
6,019
Hi. I am trying to generate a pulse every two msec in my PLC program. Thought I would be able to figure this out easily with...
19
4,376
Any recommendations for a DIY home automation suppler that has a inexpensive WiFi device that I can use to monitor my HVAC filter. Thanks, Bob O.
3,329
I have a Schneider M172 successfully communicating with a remote interface via modbus tcp. I’m trying to integrate a Schneider m171vevm4 via the...
1,301
