OT – Home HVAC Filter Pressure Differential.
Bob O
May 2003
1,873
Any recommendations for a DIY home automation suppler that has a inexpensive WiFi device that I can use to monitor my HVAC filter.
Thanks,
Bob O.
Thanks Mark!
I could change it every three months but what fun would that be? I have fairly simple home life right now so I might as well try to complicate it a bit. :)
from my jar of silly ideas:
how about a water manometer? You are only interested in this as an alarm, right? Put colored water in a clear tube and do it optically, or slightly salty water and two wires. Hmm, evaporation might be a problem, you'll probably have to replace the water several times per filter replacement. Oil might work (lower density => greater displacement).
How about a position indicator? As the filter collects dust, it will start to deform toward the fan (it also gets more effective as a filter) and you could put a wire on it that initially has insulation against a contact, but as the filter deforms the wire would be pulled up to make contact with bare wire where the insulation stops, and you could use that for an input. Basically turn your filter into the diaphragm of a pressure transducer.
Fan speed would be another indicator: as the fan clogs, the pressure drop goes up and the flow goes down (deltaP x d(V)/dt vs. constant power from motor, to first order), so the fan speed increases; google [fan performance curve]. (and I may be way off on the fan curve explanation, but the fan does run faster when inlet flow is restricted - put your hand over your desktop fan to see).
Sensitivity will be the tough nut to crack, I expect, however change should be gradual but hopefully noticeable and constant with a newish filter and then accelerate near the end.
For calibration put a piece of plastic over a new filter with a hole say 10% of the gross area of the filter.
https://temcocontrols.com/shop/pressure-sensor/
Not WiFi but has Modbus tcp. Other device's have WiFi. I personally don't use any wireless stuff in my home. Not sure if I am just old school or that I am a electrician. I am about to pull the trigger on purchasing T-stats, air quality, and bunch of stuff from them soon. It will all talk Modbus Rtu to a micrologix 1400 so I can see what's actually going on with the system. As it's already a bit complicated one 3 zone unit with fresh air in take one single zone unit so 4 T-Stats to keep track of. So i figured I'll make it less complicated by my own system (probally more complicated but this is what I do. lol) I haven't found any of the shelf HVAC controls for home automation that aren't wireless. I have been looking for almost a year. I don't like the idea of a system that depends on something that can go out of wack becuase a signal gets blocked or dropped off unexpectedly or a firmware download happens "all by it self" and I wake up mid night sweating in Nevada's 100 + degree nights.
End rant lol.
Good luck in finding what you need.
Cheap? Yup.
Complicated? Probably.
https://www.digikey.com/product-detail/en/nxp-usa-inc/MPX53DP/MPX53DP-ND/951812
7.25 PSI differential sensor, works at the ESP32's voltage range. $12.74
https://www.amazon.com/Icstation-AD620-Microvolt-Amplifier-Adjustable/dp/B072N57L7H
100uV to 300mV 1.5x to 1000x amplifier, also works at the ESP32's range. $5.99 + $2.99 shipping
https://www.amazon.com/HiLetgo-ESP-WROOM-32-Development-Microcontroller-Integrated/dp/B0718T232Z
ESP32 complete with WiFi and Bluetooth. $10.99
U tube water manometer made from a length of transparent plastic tubing
and a wi-fi web cam
I may look for a manometer “laying” around the plant and the WI-Fi would be me getting off my lazy South side to periodically look at the damn thing.
Thanks All.
Want some fun, Tape a small PLC with an analogue card to the back of your tv, mount an HMI on the top & there you go, HVAC monitoring should keep you busy for a day or too, with the spare I/O, build yourself a system that pulls a can from the fridge and delivers it to your armchair.
One other thing about the oil in the manometer (IIRC): if you put different amounts of oil on either side then it makes it more sensitive (more movement on the oil side per inH2O of head).
Inclining one of the tubes is another way to increase sensitivity.
Way OT, but controls related. I know I should find HVAC forum for this, but I am sure controls guys may have an idea: My house central HVAC...
45
14,107
Hi Everyone, I have a project involving a Beckhoff IPC with Twincat and a Yaskawa servo motor and drive. I'm trying to use the MC_HOME function...
504
I set up a Mitisubishi test system on the bench. Q03UDSPU Q173DCPU MR-J3-40B HF-KP43 HMI is a LS XP50 TTA/KP43 I am trying to use a signed...
396
I'm looking for some starter kits but there aren't so many on the market, so I'm thinking about buying individual components for my needs. I just...
2,463
We have a 5 Ton Rheem A/C unit at home We only run it in the Summertime, and sometimes in the Fall. It does have a habit of blowing fuses at...
18
2,484
