Soft Starter Recommendation Home AC
What happens is when the compressor cycles too soon after a previous cycle, pressure is built up in the high side and starting requires more current than if it rests for a while.
Solution is to adjust the dwell by settings on the thermostat or adding a on delay relay next to the contactor. So if it rests for say 5 minutes after the last cycle, pressure is disapated and starting current reduced.
Home AC condensers/heat pumps use PSC motors. The caps in use are run caps since they stay in the motor circuit continuosly while running instead of a start cap that drops out once started. Hard-start kits are sold to help with high current/hard starting compressors. These kits are basically a start cap and relay that will drop out the start cap after compressor starts.
I'd try one of the previously linked hard-start relays.
Hi, I want to start 150 SMC Flex from Studio 5000. I have the AOP and P SMC flex AOI imported in my program. I have also set the logic mask to...
311
I have a customer with an ABB PSE170-600-70 Soft starter running a 125HP Bucket Elevator motor (480V). Its been running fine for several months...
3,289
Hello all i know it isn't a plc question but with time i have seen a lot of knowledge here on motors/drive etc.. When braking with a drive, we...
18
7,715
Hello I'm wondering if it is possible to add a forward/reverse to an already existing soft starter
2,009
Hello, I am looking for a Soft starter with forward/reverse? Frequency inverters of course have this function but I am looking for a soft starter.
22
9,147
