Factory Talk Studio ME - VStudio.exe missing dll
Peter Laing
Oct 2005
BC
73
My FT Studio ME 9.00 install (Win 7) has recently broken. When I try to start it I get wa popup message as follows: "VStudio.exe The program can't start because ot1120asu.dll is missing from your computer."
I have just uninstalled - rebooted - and reinstalled it, with no success. I had a similar issue with Beckhoff TC3 a couple of months ago, and a re and re-install fixed it. I've also tried running FT Studio with the TC3 service disabled (thinking that since they both use VStudio components there might be some issue) but it has not helped.
I'm not pressed to use FT Studio at the moment, but I would like to resolve the issue.
Has anyone else has experienced a similar issue and would like to share experiences?
Thanks in advance,
Pete
I wonder if this is the result of an antivirus? I see how it could confuse this software with a virus. :)
edit: Actually, KB454556 explains the problem. Access Level: Tech Connect
Thanks DM,
As a semi retired freelancer I don't have a tech connect account but I expect that I can find someone to help me out.
Cheers,
Pete
Adding this entry:
C:\Program Files (x86)\Common Files\Rockwell
to my Windows Environment Path variable fixed the problem.
What is the solution for this problem ??? I've this problem as well. Check the ot1120asu.dll and i can find it in the folder but stil got the error
@Bino
Try the environment variable change mentioned earlier in this there, or put a copy of it in the same directory as the FT executable.
@Bino
Thx !!!, added the map / path to the system variables in Environment Variables and it worked again without error.
I am trying to enable an external alarm via computer speakers for Factory Talk Network Distributed Edition. I am using Alarm and Events setup. I...
215
I have some global objects, numeric display with associated data that pulls up a pop up screen. for the life of me i cannot figure out how it...
249
Hello everybody. I was wondering if there is a way in FTVIEW Studio to close ) view after x min without interaction . My issue is the following...
393
Is there a way to choose the base font in ME. Text in the Arial Unicode MS which is the default font on my FTVS doesnt show up properly on a...
719
Hello all, looking for ideas on getting some basic training done, I need to practice on maintenance timers and bypass switches (with a Factory...
1,340
