Help With a Diagram Please
cattiebrie
Jul 2017
Los Angeles
25
I have a homework assignment and I need help please. After helping with the answer, can you please provide what is going on in the diagram so that I can understand?
Question: A discrete 120 V ac output module is to be used to control a 230 V dc solenoid valve. Draw a diagram showing how this could be accomplished using an interposing relay.
Why are you looking for it, if you already have it?
I guess because he didn't go over his textbook well enough to understand what he's supposed to understand.
A lot of nowadays PLC programmers know how to write a program but lack basic electric knowledge. I think this situation is beginning to reflect on classrooms as well. It's about time the teachers start explaining that PLC programming is about electromechanics and that programming is only a means to control the stuff. But then again I know some teachers who never worked in the field...
i guess because he didn't go over his textbook well enough to understand what he's supposed to understand.
A lot of nowadays plc programmers know how to write a program but lack basic electric knowledge. I think this situation is beginning to reflect on classrooms as well. It's about time the teachers start explaining that plc programming is about electromechanics and that programming is only a means to control the stuff. But then again i know some teachers who never worked in the field...
+1
Many of them also seem to think that there is no need for them to develop an understanding of the process that they are attempting to control. Learning to write code efficiently alone doesn't make someone a qualified PLC programmer.
If you wanted to put a different curve in this
You could use a voltage doubler and eliminate the relays
their at many ways to achieve the same end this is just one of them
Many ways to accomplish this. I would use the 120v output from the card to actuate and isolation relay. The Isolation relay would actuate a separately sourced 120v to the coil on the contactor for the 230V DC Solenoid.
FWIW gentlemen, I assume by the original posters user name it is a lady (name is from R.A. Salvatore's fantasy novels.)
The diagram is showing the coil of the interposing relay being energized by a PLC output. When this coil is energized, the normally open contact of the interposing relay is closed, energizing the coil of the motor starter. And tell your professor one doesn't use this type of scheme without overcurrent protection or feedback from the motor overloads, otherwise resetting the the motor starter will cause the machine to start. Also (at least in the USA) we don't typically refer to a motor starter as a solenoid.
+1
I am a returning student (over 10 years out of school) and they threw me into a class where I have forgotten the lessons taught from the prerequisites of the course I'm taking. I would like to get up to speed by understanding the answers you guys are providing.
Ask lecturers if you are allowed to sit in the classes you forgot, often they will allow you to do so.
I would also recommend Lydia, my uni offers free access to Lydia. Or MIT Opencourseware.
please help me . I have to make this ladder diagram and I can’t figure it out :(
290
"Hello, I am a beginner learning about PLC. Could you please give me some advice? I want to write PLC instructions as follows: When the sensor...
18
3,414
Q(1) Design a controlling system using DVP-40ES Delta PLC for a threestory Elevator Prototype as shown in the figure below. Show in details the...
2,162
hello, i am maggiesparky and have visited this forum many times and just love it. well i have a ladder diagram question and ask for your help to...
3,856
a/ Input – X0 -> turns Output – y0, y5 Input X1 –turns OFF y5, but y0 stays ON b/ Input X0 -> turns Internal Bit M10 and Output Y0 M10 ->...
3,314
