RSLogix Studio 5000
godfrey
Apr 2002
Charlotte, NC
412
Trying to find out if the new version of 5000 (Studio) can support old projects done with the older RSLogix 5000. We have many projects in the field running older firmware from V13.04 thru V20.03 and need to keep them at those levels for now.
RSLogix will still be used for those versions, Studio5000 is really just a shell around a bunch of software for AB. Opening a sub v21 project will still launch RSLogix5000. All and all its the same and all you have to be concerned about is having all the versions installed on your computer.
You can keep all of the old RSLogix 5000 versions installed on your machine with Studio 5000. However, since you'll be running at least Windows 7 (minimum requirement of Studio 5000), you might have issues installing anything older than version 16 or so. For the really old firmwares, I would put them on an XP virtual machine.
The name change is confusing, so it's important to remember that Studio 5000 Logix Designer is no different than RSLogix 5000. It is the same software, just with a different name after version 20. Treat it just as you would any other version of RSLogix 5000, because that's literally what it is. The only new thing is that at some point in the future (Rockwell is saying 'soon', but they've been saying 'soon' since 2011) a new View Designer module will be added to Studio 5000 in order to program the new Panelview 5000 terminals. Supposedly this is coming in version 27, but again, this will not affect your old versions of software.
Since it hasn't also been mentioned, when you purchase version X, you also have the ability to selectively install any earlier major version.
So, I have a little dillemma I am trying to work through but I feel there is probably a better way. I've always liked the idea of using a VM in...
2,048
I have a micrologix 1100 that I am trying to read three data points from it on my safety plc using studio 5000. Any tips or guidance is appreciated.
845
Dear Sir, We have Windows 10 Dell laptop with RSlogix Studio 5000 installed in it. Now we have purchased a ex-proof laptop with Windows 10 and...
2,604
How can I achieve the same functionality in Studio 5000? Image 001.png for the old RSLogix500 program Image 002.png for conversion to Studio...
2,516
Hello all, I am working on a project on a CompactLogix L16ER-BB1B plc, and I was given a program that is on version 20.019, while my plc is on...
1,836
